Crack in arm rest on door panel
I am not sure how common this problem is, but from what I understand it is as it happened to me and my friend and I asked a guy who sell used Honda parts and he also said it is
What basically happened is the plastic in the arm rest, on the door, cracks from people resting the arm on it.... usually happens right about where your elbow rests.... I am just wondering if anyone else had this problem and how they may have fixed it
I know the obvious solution would be to buy a new door panel, but if I don't need to that would be great
The guy at my local body shop said he maybe able to fix it using the same stuff they use to fix plastic bumpers
any help would be great
Cheers
Cheers
Re: Crack in arm rest on door panel (kevo1586)
Can't you purchase a new arm rest? You will need a plastic welder to remove/install the new piece as honda plastic welded the arm rest to the door panel in about 12 diff. areas
nah unless someone is willing to part out that piece u got to buy a whole door pannle. I've been looking for one for a while and the only1 I've seen at the junk yard was for a manual window
rayaman2
03-16-2011 10:15 AM
