Couple Questions
Couple Questions
I just got my B18c1 swap for my 98 civic hx. I need a Power Steering bracket can i use my old one off my motor or do i need a GSR Bracket. 2nd I got a 01 gsr motor so im not sure if i can use the p72 ecu from the 01 or do I have to get a 96-98 P72 ECU?
Re: Couple Questions (Civichx1998)
I am 80% sure you have to use the GSR steering bracket, there may be some other ones but I don't think you can use an hx bracket.
I'm a bit confused on your question:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Civichx1998" »</TD></TR><TR><TD CLASS="quote">2nd I got a 01 gsr motor so im not sure if i can use the p72 ecu from the 01 or do I have to get a 96-98 P72 ECU?</TD></TR></TABLE>
Can you use an '01 GSR ECU with an '01 GSR engine or do you have to use a '96 - '98 GSR ECU?
Welp, I'd have to say you could probably use the '01 GSR ECU with the '01 GSR engine...
Re: Couple Questions (Syndacate)
Yea thats what i thought on the Bracket now i just have to find one.
The ECU and motor would work together.. BUT My car is a OBD2A the ECU is a OBD2B i dont think it will plug in correctly. But im not sure thats why i was asking cause if i do i have to find me a OBD2A ECU before next weekend when the motor is going in
