cotter pin?
Old 03-28-2005, 05:02 PM
deviant1's Avatar
Default cotter pin?
Is there a specific size for cotter pins? I'm referring to the cotter pin for the lower ball joint. Would Kragen or AutoZone have them?
Old 03-28-2005, 05:07 PM
e jay one's Avatar
Default Re: cotter pin? (deviant1)
did you loose the old one if so tell them its for a balljoing just as long as it fits in the hole you should be good and yea kragen or autozone will have it even orchard has em.
Old 03-28-2005, 05:08 PM
pdiggitydogg's Avatar
nah, I just ones that fit (the largest that fit)
I bought a big box of em at the hardware store.
Dont be like this fool ^ and reuse the old ones......
Any autoparts store will have them too (should). But a big box is cheaper at the hardware store/Ho Depot
Old 03-28-2005, 07:40 PM
deviant1's Avatar
Default Re: (pdiggitydogg)
Home Depot's site lists brass pins, are those usable on suspension components? It was a box of 10 for like 2.49
Old 03-28-2005, 08:40 PM
Farmer Brown's Avatar
Default Re: (deviant1)
You dont want brass.
Old 03-28-2005, 08:49 PM
Luserkid's Avatar
Default Re: (Djaric)
Go to autozone or something and get a nice mix box of them. Its usually like 3 bucks for about 20 varies sizes.
Old 03-29-2005, 06:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 &raquo;</TD></TR><TR><TD CLASS="quote">Home Depot's site lists brass pins, are those usable on suspension components? It was a box of 10 for like 2.49</TD></TR></TABLE>
Weird. I was just there last week and they had a huge box for $3. Not brass.
Old 03-29-2005, 06:39 AM
Ricey McRicerton's Avatar
If I were you, I'd go with the reusable ones. I can't remember what they're called, but they're shaped like a D instead of the one that you bend into shape. I used to use them on my gokart all the time.
Old 03-29-2005, 11:49 AM
deviant1's Avatar
Default Re: (Ricey McRicerton)
good info, thanks guys!
Old 03-29-2005, 12:27 PM
Boilermaker1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">If I were you, I'd go with the reusable ones. I can't remember what they're called, but they're shaped like a D instead of the one that you bend into shape. I used to use them on my gokart all the time. </TD></TR></TABLE>
I believe you're talking about a hitchpin (one side is straight, the other side has a wave in it. You put the straight side through the hole and the other around the bolt). They also work just fine. Those are sized though... make sure you buy one thats big enough to close when you pop it in.
itr114
Honda Fit
03-05-2008 07:25 AM
integra15
Audio / Security / Video
10-10-2006 07:36 AM
DBAl
12
07-11-2006 12:05 PM
shibby
12-16-2003 08:12 PM
RiceRacist
15
09-24-2003 10:11 PM
Quick Reply: cotter pin?
