corner lights not working
I have a 95 civic with side marker lights on the side. I didnt wire them and they were on there before i bought the car. The problem is that since i have had the car the right corner wont blink but the light works, and the left blinker works but the parking light wont come on. Anyone had this problem or can tell me how to take the 1/4 panel off.
Unceasing Measure
Re: corner lights not working (flyingduck04)
You can take the quarter panel - that's fender here in the States - off pretty easilly. There are a couple 10mm bolts behind the door that you'll want to get with a 10 inch extension, universal joint and that 10mm socket. There are a couple 10mm bolts on the bottom of the car under the sideskirt (I was able to get my fenders off without completely removing the skirts) and there are a series of bolts - 10mm - holding the fender to the car in the engine bay. Pretty simple stuff, but don't pull too hard when you get it undone: they're fragile and easy to bend/dent.
i have never had this problem... but i'm pretty sure that you should not have to take the quarter panel off.... your corner lens(if your headlights are 2 pieces) should lock into place and be held in by only one screw connected to the side of the main headlight.
If you sorta tug the corner out, you'll see the screw.
Hope this helps, it'll allow you to get to the lightbulb and the wiring. BTW, i have a 95 civic.
Re: corner lights not working (nchyflyer)
i dont think the corner light is the problem, its the sidemarker light wiring. Thats what i am having trouble getting to.
1bar
Honda Motorcycles
10-06-2005 06:29 AM
