coolant temp sensor 94 ex
Old 10-21-2012, 01:43 PM
tanhanson94's Avatar
Default coolant temp sensor 94 ex
went to the auto parts store and i got my part but i do not know where it is located. it is the coolant temp sensor here is the link to the one i purchased
http://www.google.com/imgres?um=1&hl...23&tx=29&ty=52
could someone please tell me where its located and how to replace it. thanks
Old 10-21-2012, 02:15 PM
Resident Gearhead
BryanM.'s Avatar
Default Re: coolant temp sensor 94 ex
That's the 1 wire coolant temp sensor for the coolant temp gauge. Located under the distributor; thread out and thread in not much procedure here.
Old 10-21-2012, 08:27 PM
do you have to remove the distributor to get at it or is it possible to do it without removal of distributor
Old 10-21-2012, 08:30 PM
Former User's Avatar
Why did you need to replace the temp sending unit?
Old 10-22-2012, 06:42 AM
zcole1993's Avatar
You will probably have to remove the distributor if you want to make the job easy.
Old 10-24-2012, 08:54 PM
okay so i finished up the job the other day and the temp gauge works fine now, but car still pulsates idle until the engine is at normal temp, so waht causes this
Old 10-24-2012, 09:04 PM
Clean the IACV and FITV and also bleed the cooling system.
Old 10-25-2012, 10:22 AM
how do you bleed the cooling system?
Old 10-25-2012, 10:27 AM
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
Old 10-25-2012, 08:19 PM
thank you i will do that in the morning. does the need for bleeding the cooling system have anything to do with the temperature of my heater. its semi warm but definately could be hotter
Old 10-25-2012, 08:33 PM
Air bubbles trapped in the cooling system or a low coolant level can prevent the heater from working properly.
cehcivic15
15
02-22-2010 12:31 PM
theeogflip
08-08-2008 12:05 PM
busyychild
05-06-2008 11:09 AM
TonyRomo
11-17-2007 12:23 AM
JoshM
06-02-2002 06:11 PM
Quick Reply: coolant temp sensor 94 ex
