Converting Eg to RHD?
Hey i was wondering if anyone has done this before.
How hard was it? Also if there is a place where i could buy a everything to do the switch, or do you have to go looking for everything?
Thanks for any info
Thanks for any info
Re: Converting Eg to RHD?
You can buy it complete from www.hmotorsonline.com
Be prepared for some serious qwork. Double check all your measurements and linign things up before you start welding. Make sure everything is sealed well along the seams. Test fit, test fit, test fit.
http://hmotorsonline.com/shop/whatsn...95%20Civic%27s
Scroll down and it is the 5th item from the bottom in the EG sections. Item reads "EG6 OR EG9 Right Hand Drive Front Clip"
ok so after finding on there, some other questions,
stock hood would fit the same im assuming?
usdm front bumper, will it fit the RHD front clip? same with headlights?
could u to the conversion without a clip?
but everything else needed for the swap, i know you would have to cut new firewall but thats all i know
