confused about dual cam engines
Take a b16 head, add sexy cams, valves & springs, P&P. Take a b18 block, add forged rods and pistons, maybe a crank, an oil cooler, whatever other accessories you like..
what do I call this? I wanna call it a type-r cuz thats what Honda called a b16 head on a b18 block. If I sand the stamps off, what would you call it?
what if use a regular Integra crank and matching forged rods and 12:1 pistons?
i really hate saying LS when referring to a Honda cuz the GM LS engine kicks lots of *** it has their version of i-vtec now, matching the MPG of our engines in a multi-ton truck. With lots more power&torque.
Re: confused about dual cam engines
Which b18 block there's different ones you know....no it' NOT a type r most likely an LS/Vtec or for some reason you wanted to put a b16 head on a gsr(b18c1) block it would be referred to as a hybrid although no gains to be had by doing that. Why shave the stamps so you can try and scam someone ? there's 2 integra cranks 87mm found in the ITR/GSR(1.8l) and an 89mm in the ls(b18-non vtec) also found in the b20(CRV) engine.
What if I get am given an empty block that says b18c5, and install a LS crank, a nice forged copy of LS rods, and some about 12:1 forged pistons?
And no I'm not trying to scam ppl in trying to understand all these made-up technical terms thrown around here. All I understand is that I have a EH9 with its d16z6.
But once you start messing with pistons etc it doesn't matter as much what the block it is, especially if you sleeve it/swapping cranks then all that c5 c1 b1 **** goes out the door more or less.
So if I take an 1.8a/b shortblock w/ high compression pistons, and put a built b16 head on it I really can't call that a fake type r without ppl here complaining about my irregular use of jargon?
i may be mistaken but it seems to me like there arnt major differences between a factory 1.8 block w/ 1.6head and if have an engine builder do it.
It's called an LSV....I don't get what's so bad about a term EVERONE uses, wrong there never were a1/b1 blocks with a 1.6l head on them from the factory thus the required extras to get a hybrid lsv/b20v going. The itr head has light factory porting and valve job along with different cams and valve springs+ retainers then the regular b16a1/2 etc heads.
Cool Cool Island Breezes. BOY-EE
B18 LS blocks are not the same as the P72 (B18C/B18C1/B18C5/B16B) block. The B18A/B has slightly higher displacement and is taller.
Don't "fake type R" anything. It's the lamest thing possible.
A real B18C-R or B18C5 has a fairly long list of features that make it unique. Lighter rotating assembly, it has oil squirters (non VTEC blocks do not), some years have a hand ported head, more agressive cams and valve train, higher comp pistons, carefully balanced crank (crank weighs more than gsr crank), oil cooler, etc.
It's not just a B18 block and a B16 head.
Man U FTW
The type R craze is because ***** see type R's as the fastest and rarest model available.
If you really look into it, though, every single type R model car is refined into something amazing. I'm not being sarcastic. All those small and seemingly insignificant differences add up to something substantial. There's a lot of careful engineering and precision that goes into anything that's "type R". Nobody gives a **** about that though. Lol.
I definitely do. After having owned an ITR (01-624), I really can appreciate it. OEM Type R parts are like track/race ready parts with Honda fit, finish, quality, and low cost. **** straight amazes me.
All these fruitcakes on the internet want to "clone" type R cars or parts do it so half assedly. Apparently, a RSX or Integra with a spoiler is a "Type R" or "Type R clone", as indicated by the "Type R" stickers on the side. Same goes with GSR rotating assemblies with a B16 head. How the f#&k is that a type R clone motor? That'd be like cloning a sheep and coming out with a cabbage and saying "same thing, right?!!".
/rant
Fish Twig
Each Honda b-series motor is built differently that is why they all have different names. B16A2, B18C1, B18C5 and jdm counterparts B16A, B18C(SIR-G AND TYPE R). There are different variations of the TYPE R motor as well and you might even find them with a different #.
Lol...OP, every company has their own version of variable valve timing.
What does GM's VVT have anything to do with a LS integra B18B block? You think when you say that your car has "LS VTEC", someone is going to think you have a LS1 with 2 Honda heads on it? Cuz that would be dope. And nobody's going to think that.
Would it make you feel better to call it RS VTEC? GS VTEC? SE VTEC?
BTW...do GM LS engines really have variable valve timing now? How? Theres 1 cam for 8 cylinders. How would you run variable timing? I know they don't have variable lift. Do they? That'd be a ridiculously fast engine. No....they don't. Again, its 1 cam for 8 cylinders.
Why is it so important to call it something?
I usually refer to mine as "my engine", unless someone asks for specifics. I guess I could call it Mike or Jeff as well, but kids might not think it's cool?
no one wants to hear the truth
I'm new to these little high performance Hondas. I kno the Toyotas better, 5 valve per cylinder (black) or factory supercharged (Z) 1.6s for the lil-high output engines. If I had the money to make a real track car it'd be a supra, but then id probably still leave it as prostreet instead of caged, gutted, harness, etc
@b serious the LS engines do have VVT. The oil pressure actuates the cam, and there's cylinder bank deactivation just as Honda advertised in the 2005+ v6s. Like you said tho they're not over head cam and only 2 valve per cylinder vs the japanese/german 4 or 5 valves and 1-2 cams. so they cant have 1 intake valve doing one thing and another doing something else
So...they're changing the cam timing for the entire motor all at once? Intake and exhaust cams for all 8 cylinders? Just....change timing across the board? Seems crazy. Honda has iVTEC on their SOHC V6. But I'm not sure that it means the same thing as the iVTEC on the K series.
Not that any of that is relevant. Just interesting.
VTEC and iVTEC mean and do different things, BTW.
To put it in familar terms, iVTEC works either like VVTLi or VVTi on toyotas. It depends on the engine. But it's all called iVTEC.
VTEC always means timing AND lift AND duration change. But there are usually only 2 settings. High cam on or high cam off.
There are weird variations of VTEC that operate a different amount of valves also. VTEC-E is what this is called.
@b serious
yeah the cam is adjusted for low-rpm to increase torque, and adjusted at high-rpm to increase power. They're not as good as the Japanese at the technology, being that the japs pioneered it and have been using it for what, 20 years? I still think its funny that the lean-burn Vtec-e from about 20 years ago still has much better MPG than anything America can produce even the hybrid cars
Chevy cruze eco gets 40+ MPG, doesn't it? Plus it has CRAZY things like cruise control, safety features, AC, PS, real back seats, and...more than 50-100hp.
Then again, so does the civic EX.
If you loved me, you'd all sell me your magic cards to me today
@b serious
Consumers are also a lot more demanding. Car gets 50mpg but has no fu#&ing power windows, or arctic AC, or 75 power outlets, or a 60" TV DVD NAV monitor?!! Non seller. Banned for life from all ports.
Plus safety and emissions constraints. Nobody's driving lean burn NOx emitting shoe boxes like the 96-00 Civic HX anymore.
Do the ITR oil squirters make a worthwhile difference? If i rev a (a)(b) block over nine thousand RPMs is it gonna have oil starvation? I wonder if thats a common problem or not for ppl with fast non-vtec shortblocks
