computers?
computers?
hey i have a 98 honda civic dx and im swappin in a b20b and need to know what computer i need. i went to the junk yard and pulled one out of a 94 integra and it was a p75. what kind of computer do i need and what car should i get it out of?
Re: computers?
the ECU is ODB1.... 1994.....
Re: computers?
ok and besides the computer what else do i need to make this swap? i really need help with all this everyone i talk to is tellin me something different. so will the b20 intake work? and the distributor i was told that u have to take parts from the b20 and from the d16 and interchange some parts.... i dont know what all i need to get from the junk yard or buy...
Re: computers?
and for the wiring harness do i need the version 1 or version 2? http://www.lightningmotorsports.com/sveharness.htm
Re: computers?
96-97 b20b intake manifold will not work, it has the giraffe neck (tall) intake manifold and must be switch to a aftermarket one or a b18b, b16 maniold, gs-r will not work. If you have the 98+ b20b 9.1 comp. model it already has the low intake manifold and should clear the hood on any civic/integra/sol ect. As for the ECU i think i have a few OBD2 P75's at the shop gimme a call tomm if intrested and ill let you know. Number is on the bottom.
Re: computers?
BTW, a B20 ecu will work also, its a P7J if im not mistaken. Since majority of CRV's were auto chances are you will only find those. It will altho throw cel's (check engine lights) since it is not picking up the senors and solinoids from the auto trans. Motor will run fine tho.
Re: computers?
but if i get a computer conversion kit can i use the p75 computer? so i wont get those lights... cause i live in cali and we can get B.A.R. tested sucks ***. but what about the distributor? anything else ill need to swap over?
Re: computers?
good luck. eff cali! iLL is where its at
Re: computers?
#1- As far as B.A.R. for a B20 its impossible to B.A.R. a B20 to make it legal since its considered a light truck engine.
#2- If you dont want to worry about lights from the PIGS then you should have just bought a GSR or a Si engine and get it B.A.R. and called it a day. If the stations are open which i dont recall if they have re-opened or not.
Re: computers?
bingo.
