Comptech Swaybar Tiebar owners - which exhaust do you use? 92-95/EG/EH Civics ONLY Please.
Old 12-04-2003, 08:11 PM
JeffS's Avatar
Default Comptech Swaybar Tiebar owners - which exhaust do you use?
[edit] 92-95 civic hatchback only
I put one of these bars on my track hatch about two years ago and went though all kinds of hell trying to find an exhaust that clears the bar. I ended up having to build an exhaust myself to get clearance. I want to put another one on my new daily driver and need to get some definite answers as to what fits. I'd like to run the Apex'i WS or something quiet if I can.
I'll start:
Thermal - pipe lays on the swaybar
Pacesetter (don't ask) - pipe lays on the bar & canister rubs
Buddy Club Spec 2 - fits perfectly (and my ears still hurt)
Stock - does not rub
Spoon axleback - does not rub
thx.
Modified by JeffS at 3:01 PM 12/10/2003
Old 12-04-2003, 09:24 PM
The Internet Tough Guy's Avatar
Default Re: Comptech Swaybar Tiebar owners - which exhaust do you use? (JeffS)
i run the stock exhaust well, it fits and its quiet.... isn't this bar combo great though? i love it.
bump because i need to pick out my exhaust based on this thingy too.
Old 12-04-2003, 09:30 PM
Skunk_it's Avatar
Whats up bro? I ran that sway bar and tie bar combo on my 02 Si and my 00 Si and the exhaust that fits is the comptech and the stock. On my 02 Si I used a Greddy for a little while then switched to the comptech it is a great exhaust with a great sound and is not loud at all. I recommend going with comptech.
This is personal experience talking.
Old 12-05-2003, 07:38 AM
hybridcivicex's Avatar
I have the HKS Hi-Power and everynow and then it rubs, kind of annoying, but it's not a constant thing.
EDIT: sorry, didn't see your edit for a hatch
Old 12-05-2003, 07:39 AM
JRSC EM1's Avatar
Bump
I have one on my 00 Si with a GReddy EVO, and would like to get one for my 95 CX. Anyone know if the RSR would work on that 95 Hatch?
Old 12-05-2003, 08:16 AM
RacerXI's Avatar
Default Re: Comptech Swaybar Tiebar owners - which exhaust do you use? (JRSC EM1)
99-00 Si with the comptech. I have a tanabe racing medallion.
Old 12-05-2003, 01:22 PM
careawholelot's Avatar
bump i got rs*r exhaust and want to get the comptech sway/tie combo for 94 cx would like to know if it would clear also
Old 12-05-2003, 01:35 PM
slammed_93_hatch's Avatar
Default Re: Comptech Swaybar Tiebar owners - which exhaust do you use? (Skunk_it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk_it &raquo;</TD></TR><TR><TD CLASS="quote">Whats up bro? I ran that sway bar and tie bar combo on my 02 Si and my 00 Si and the exhaust that fits is the comptech and the stock. On my 02 Si I used a Greddy for a little while then switched to the comptech it is a great exhaust with a great sound and is not loud at all. I recommend going with comptech.
This is personal experience talking.</TD></TR></TABLE>
he is talking about an EG hatch. i don't have the comptech setup but i have the SRR setup and i also have a comptech axel back. i had to get the pipeing redone so that it clears and now i have to go back and have the muffler pushed out futher so that it will fit.
when you are puting a clasic style muffler on a EG hatch you get kinda screwed if you have a sway/tie bar combo. there is such lil room back there that the muffleing part of the muffler is a tight squeez without a sway/tie bar combo so when you throw that into the mix you are kinda left with having to customize. now i haven't tried all systems out but i took some messurements and if i remeber correctly you need to find a muffler were the body of it is less than 10 inchs. now even with a muffler around 10 inchs you will need to do alil hackin on the bumber most likely, unless you want to run a huge dip in the pipeing which isn't good for flow.
Old 12-05-2003, 01:49 PM
Default Re: Comptech Swaybar Tiebar owners - which exhaust do you use? (slammed_93_hatch)
here is a pic of it, not that great but you get the idea, there is come cuting that was from my old exhaust and the new stuff is over to the drivers side of the car. But more needs to be done and my muffler needs to be pushed out even futher.
and yes thats a comptech muffler, you can see i left alil blang action were the label is, and i also cut off there tip and used muffler pipeing as a new tip. I didn't like the comptech's blangin tip
Old 12-05-2003, 02:08 PM
JeffS's Avatar
I'll try to take pics of the exhaust I built for my other car sometime this weekend. I'll probably have to jack it up and take the wheel off to get a good shot.
It's 2.5" piping with a Magnaflow oval exhaust at the rear. what I did is run the piping up over the lca/swaybar, then just as it starts to angle down, I attached the muffler. The muffler is angled down towards the rear of the car. You can't tell though because it's painted black and tucked almost completely inside the rear bumper area.
I was hoping to avoid having to go through that again, but I guess at least I'd know it was going to fit...
Old 12-05-2003, 02:16 PM
try and find out how long the ES oval is. i thought about doing this after i found out there needed to be mods to the comptech but coudln't find out how long it is. My freind weld and fab's alot of 4 wheels drive parts and has a mandrel bender, so over Xmas break we are gona see what we can do to take care of it. GOing the custom route isn't that hard and it garuntees no problems
Old 12-05-2003, 02:27 PM
B_Something's Avatar
What's a good price on these combos?
Old 12-05-2003, 03:27 PM
Default Re: Comptech Swaybar Tiebar owners - which exhaust do you use? (B_Something)
350 was the cheapest i found - well worth it too
Old 12-05-2003, 04:13 PM
i paid 400 for LCA, sway, and tie bar, im gona be purchasing the comptech setup this summer so i can compare the too.
Old 12-08-2003, 10:37 AM
JeffS's Avatar
back up... still haven't gotten a single useful answer.
Old 12-10-2003, 08:44 AM
Boba Connoisseur
SkyeC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">back up... still haven't gotten a single useful answer.</TD></TR></TABLE>
No ****, right?
With all the money people spend on green coil-overs here, I haven't been able to find more than a couple people that have this Comptech set-up.
I know it fits with the Spoon axle-back on a 92-95 hatch because a local autocrosser is running that set-up.
Old 12-10-2003, 09:34 AM
racecarpete's Avatar
Default Re: Comptech Swaybar Tiebar owners - which exhaust do you use? (SkyeC)
I have the comptech setup and I run a skunk2 exhaust, fits fine. My exhaust rattles a bit but it's not from the sway/tie bar.
Old 12-10-2003, 09:53 AM
JeffS's Avatar
Default Re: Comptech Swaybar Tiebar owners - which exhaust do you use? (SilverCivic2k)
Thanks, but this is for 92-95 hatchbacks only.
Old 12-10-2003, 10:53 AM
Johnny Tran's Avatar
93 snatchsack....stock exhaust, doesnt rub.
there's one reasonable answer for ya....stunna.
Old 12-10-2003, 11:16 AM
King Tut33's Avatar
I know on my SRR setup, the APEX'i Dunk would not work with it. That is why I got the APEX'i N1 and cause it goes under the LCA it should work with any tie/sway combo setups:
Old 12-11-2003, 09:12 PM
JeffS's Avatar
Default Re: Comptech Swaybar Tiebar owners - which exhaust do you use? (King Tut33)
bump
Old 01-10-2004, 05:24 PM
redman223's Avatar
I used to have the N1 on my car, until it was destroyed by a small object in the road The only gripe I had about it was that since it goes under the lca, it sits REALLY low to the ground, and can get damaged easily...
Old 02-11-2004, 11:32 AM
Boba Connoisseur
SkyeC's Avatar
Default Re: Comptech Swaybar Tiebar owners - which exhaust do you use? (redman223)
Greddy SP fits, barely:
and
Old 02-11-2004, 11:48 AM
hayabusa160's Avatar
i got a srr tie bay and sway bar combo on my eg and my apexi ws cleared the sway bar tight fit but there is 0 cleance issues i'll get some pics when i get the chance.
spankey167
16
06-06-2006 08:43 AM
CivicSiRacer
17
03-22-2005 05:08 AM
AutoXer
11
06-19-2004 12:16 PM
AutoXer
06-18-2004 09:44 AM
fake mugen power
01-22-2004 02:10 PM
Quick Reply: Comptech Swaybar Tiebar owners - which exhaust do you use? 92-95/EG/EH Civics ONLY Please.
