Comptech Rear Sway Question
Old 04-22-2002, 05:18 PM
netnutshatch's Avatar
Default Comptech Rear Sway Question
Now I know the version for the 94-01 Integra will fit EG hatchbacks if you install Integra LCA's, but my question is this: Are there any clearance issues with the exhaust piping hitting the bar with this setup? Anybody tried this setup?
Old 05-23-2002, 09:13 PM
JeffS's Avatar
Default Re: Comptech Rear Sway Question (netnutshatch)
This is an old topic, but I'm just adding to the archives...
It will not fit with a Thermal exhaust... I'm trying to find an exhaust that will work now.
Old 05-24-2002, 06:37 AM
Jason kiDD's Avatar
Default Re: Comptech Rear Sway Question (JeffS)
And do you need to replace the LCA's... Wont they still work with the stock Eg's??
Old 05-24-2002, 11:20 AM
JeffS's Avatar
Default Re: Comptech Rear Sway Question (Jason kiDD)
If the car didn't come with a rear swaybar, then stock lca's don't have the screw hole to mount the end-links in.... so yes, you generally have to change the lca's.
I'm not up on my EG trivia enough to know what models have a rear swaybar if any. I know my 2 CX's don't. (didn't).
Old 05-24-2002, 11:23 AM
Jason kiDD's Avatar
Ohh but I am saying if worse comes to worse then cant you just drill holes in yourself?? And probably the EX/SI came with such advancements..
Old 05-24-2002, 11:25 AM
JeffS's Avatar
Ummm... maybe you could if you really wanted to, but I wouldn't.
Old 05-24-2002, 11:28 AM
Jason kiDD's Avatar
Cool.
Old 05-24-2002, 11:32 AM
BROOD's Avatar
You mean drill the Civic (non-sway bar) lcas so they will accept swaybar endlinks? No, that isn't very feasable. You need to look at each of them and compare the differences.
Civic lcas - no endlink mounting holes, lca is strait over the whole length.
Integra/DelSol Vtec lcas - faced and threaded endlonk mounting holes, lca is clearenced (bent) to clear the sway bar.
You need lcas from a DelSol Vtec or Integra......simply put
Old 05-24-2002, 11:37 AM
Jason kiDD's Avatar
Default Re: Comptech Rear Sway Question (SLPR)
Nice desription.. Does this fact apply to the front as well..
Old 05-24-2002, 11:45 AM
BROOD's Avatar
The front lcas? No not really.
The 92-95 Civic outer lca is the same as the 94+ Integra but the inner lca can be different depending on the Civic model.
The Integra inner lca is the same as the Vtec equipped 92-95 Civics. So if you have a non-Vtec Civic you will need Integra inner lcas. Just bolt them to you Civic outer lcas. If you have a Vtec equipped Civic, then use your inner lcas.
SLPR......
It has been awhile since I've looked at this stuff so I may need some correcting here.
[Modified by SLPR, 12:47 PM 5/24/2002]
Old 05-24-2002, 11:53 AM
Jason kiDD's Avatar
Its cool, thanks for the input..
EgSalad
12-08-2007 08:36 AM
EgSalad
Suspension & Brakes
10-11-2007 05:48 PM
spankey167
16
06-06-2006 08:43 AM
Street Ghost
04-19-2004 04:52 PM
Street Ghost
04-19-2004 10:10 AM
Quick Reply: Comptech Rear Sway Question
