Compression Question ??? B20Vtec Type R pistons
i was just curious what kinda compression i would be looking at with a B20 block 95 GSR head and Type R pistons?
Re: Compression Question ??? B20Vtec Type R pistons (nitrousjunkieCRX)
0 compression. Type R pistons are 81mm and B20 are 84mm bore. You'll need to buy something aftermarket.
EDIT: You may be able to work something out with an LS block though.
Re: Compression Question ??? B20Vtec Type R pistons (delScho)
all stock internals, what would give me low compression for nitrous or turbo? some aftermarket pistons made for the b20Vtec?
The ones I have seen advertised quoted compression specs for B20 with B16 head. Arias and Wiseco among other make them. And if you don't see the numbers you want, then you can order whatever you like for your setup. I would also think about doing the rods. Then there's a whole debate about sleeves cracking and open decks yada yada yada. You can search for all of that stuff. I'm sure it's around here somewhere.
AdrenalineAngel
10-23-2019 10:38 PM
