COMPRESSION NUMBERS...LOW?
I was just recalling, a while ago i did a compression test on my car.
170
170
168
180
My USDM b16a2 has only 40k miles on is...so now I am thinking this is rather low. True or false. and why. And how much is this hurting my performance.
170
170
168
180
Re: COMPRESSION NUMBERS...LOW? (birds_sol_94)
Warm or cold? full throttle no throttle?
Either way those look like good numbers, try a valve adjusmtnet on the low one.
Re: (birds_sol_94)
Consistency is more important than the actual numerical values, and those look pretty good to me. As stated before, make sure the throttle is open. Having the engine warm will help, but not all that much.
Re: (ddd4114)
This was done WOT for 4-5 cranks. Engine was probably not full operating temp.
How do i adjust the valve, and what am I adjusting it to?
One or more of my valves does make quite a LOT of noise.. so maybe its got extra play
Re: (drumminforev)
like the guy posted above.. Consistancy is what you're looking for as long as its not too low
To adjust the valve you need to get the feeler gauge and the valve adjuster tool..
If you do a search there should be some threads with pics
Re: COMPRESSION NUMBERS...LOW? (. M i c h a e l)
well i do have 15psi between two of the cyclinders. So is the only way to fix this new piston rings?
Re: COMPRESSION NUMBERS...LOW? (drumminforev)
no, it could be many things: valves leaking, valve stem seals, head gasket leaking, the list goes on. If you're concerned, do a leakdown test.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev »</TD></TR><TR><TD CLASS="quote">well i do have 15psi between two of the cyclinders. So is the only way to fix this new piston rings?</TD></TR></TABLE>
People always seem to think that compression tests are all about getting the highest possible numbers. You are looking for LARGE variances. 15psi isn't enough to cause that much of concern. Like Luserkid mentioned, try adjusting the valves and retesting. Doesn't take much in the way of valve adjustment to drop compression results significantly. Doesn't always mean there is a 'problem'.
dotmichael to you
Re: COMPRESSION NUMBERS...LOW? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
People always seem to think that compression tests are all about getting the highest possible numbers. You are looking for LARGE variances. 15psi isn't enough to cause that much of concern. Like Luserkid mentioned, try adjusting the valves and retesting. Doesn't take much in the way of valve adjustment to drop compression results significantly. Doesn't always mean there is a 'problem'.</TD></TR></TABLE>
True that it doesnt mean there is a serious problem, but a 15 PSI difference is definitely cause for concern and needs to be further checked out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l »</TD></TR><TR><TD CLASS="quote">
True that it doesnt mean there is a serious problem, but a 15 PSI difference is definitely cause for concern and needs to be further checked out.</TD></TR></TABLE>
Might want to study the helms a little closer. You will see you are wrong. Check the valve lash, then have your "concern".
2wheelhunter
10
09-02-2007 01:07 PM
drumminforev
13
09-19-2006 05:42 PM
