Complete ek4 for spares!
and im going to swap everything over from my 1998 1.6 vtec into a 1.4 (1999 facelift model) civc hatch.
can i use the same wiring loom which is in my 1.4 or do i need my vtec loom?
what problems am i most likely to see when it comes to swapping of the ecu..
any links to some help would be great, ive been searching a while now.
cheers
cheers
Re: Complete ek4 for spares!
the "loom" or wire harness must match the chassis, not the engine. so you will need your current "loom" and you will need an obd2a-obd2b ecu adapter since your going from a 98 to a 99 chassis, and you will use your 1.6 vtec ecu.
great. so only needing a ecu adapter
Im guessing it must be fairly easy to get one?? im in the uk so if anyone has info on wher to pick one up from..
thanks
thanks
what if i wer to find a ecu off a 1999 civic 1.6vtec... that would surely be the best best???
would it just be a simple case of swapping them over..?
cityofcaterpillars
Engine Management and Tuning
04-13-2016 07:06 PM
