ECU Wiring
ECU Wiring
Hi all, I have been fixing up the interior of my Del Sol, and after peeling back the carpet, I discovered some wires that were not connected. Could I get some help in identifying the wires? I'm not entirely sure if the ECU is original to the Del Sol, or if it has been replaced.
I am unable to attach images for some reason, it get stuck at 90% uploading. Here are the images of the wires on Google Drive:
First image, red/blue with red/orange wires together, thicker red wire, thicker "bronze" wire, and standalone red wire: https://drive.google.com/file/d/1FRb...ew?usp=sharing
Second image, blue connector with green connector: https://drive.google.com/file/d/11g5...ew?usp=sharing
Keep in mind that my car is mid engine converted, so some engine wires may go to the back rather than the front. The car runs well, except for the radiator fan, which does not work (could some of the wires be for that?). The rear speakers are removed, although it doesn't seem like any of those colors match the speaker wires colors. The rear glass is fixed in place as well, since it cannot roll down due to the engine, so no motor there. Lmk if any of you have some insight!
Re: ECU Wiring
Update: I looked up the colors for the rear glass motor and it appears to be red/yellow and red/blue, can anyone confirm if those wires pictured are indeed for the rear window motor?
mrredrocker
10-08-2005 01:18 PM
