cold air intake...
Old 08-18-2004, 12:51 PM
rac3rb0i's Avatar
Default cold air intake...
ok i don't know shiet about my car does anyone have a installation for dumbies on installing ur cold air intake... got a 96 civic ex.... just got my cold air intake and i don't want to spend the 30 bucks and have the shop do it ... so need help installing it... if it isn't too hard.... thanx....
Modified by rac3rb0i at 8:39 PM 8/18/2004
rac3rb0i is offline
Old 08-18-2004, 12:55 PM
XiiiXiii's Avatar
Default Re: cold air intake... (rac3rb0i)
shouldn't be too hard as long as you can turn a wrench.
I know with my car (1999) you have to take the front bumper off, but thats just taking out 4 screws and a bunch of clips.
Seriously its not hard at all to install an intake
XiiiXiii is offline
Old 08-18-2004, 12:58 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rac3rb0i &raquo;</TD></TR><TR><TD CLASS="quote">just got my cold air intake and i don't want to spend the 30 bucks and have the shop do it ... so need help installing it... if it isn't too hard.... thanx</TD></TR></TABLE>
What car? What motor? Save the money, do it yourself. You'll learn a little also.
rodrez. is offline
Old 08-18-2004, 01:23 PM
CAI install is easy. just grab the tools and go at it. what intake?
AnToNy is offline
Old 08-18-2004, 01:27 PM
Electrician
Deemeetree's Avatar
All you need it a Phillips screwdriver, 10mm socket, ratchet, and an extension.
Deemeetree is offline
Old 08-18-2004, 02:07 PM
chronodyne28's Avatar
Default Re: cold air intake... (XiiiXiii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XiiiXiii &raquo;</TD></TR><TR><TD CLASS="quote">shouldn't be too hard as long as you can turn a wrench.
Seriously its not hard at all to install an intake</TD></TR></TABLE>
Don't all civics from 92 and up require the bumper to be removed during installation for a cai?
chronodyne28 is offline
Old 08-18-2004, 02:17 PM
hondainspired's Avatar
Default Re: cold air intake... (chronodyne28)
wow.... yea.. easy.... yea... search... but if this doesn't get flamed then there are plenty of guys in here that will help you out..
hondainspired is offline
Old 08-18-2004, 02:20 PM
Spirit Iron knife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chronodyne28 &raquo;</TD></TR><TR><TD CLASS="quote">
Don't all civics from 92 and up require the bumper to be removed during installation for a cai?</TD></TR></TABLE>
Pretty much. You need to get rid of that fat resonator box.
Racerboi, the install is pretty straight forward. Remove the bumper cover, and the pull back the fender liner. Remove the resonator box (the bolts are sort of behind it, takes a second to find them), and remove the air box in the bay, and of course the rubber intake arm. Carefully place the new intake pipe into the bay, and loosely attach it to the throttle body with the supplied silicone hose and hose clamps. Connect the new cone filer, and put, double check the connections so they're secure, and you're not rubbing on anything. You'll probably have a spacer or grommet that goes between the car and the piping to hold it steady, make sure to secure it properly. Reinstall the liner and bumper, and you're good.
Spirit Iron knife is offline
Old 08-18-2004, 02:27 PM
Default Re: cold air intake... (Cult of Staxx)
i've never had to remove the bumper, just take off the wheel and pull back the fender lining. just unbolt the u-shaped tube from the box. take apart as much as u can connected to the resonator box, that will make it easier.
AnToNy is offline
Old 08-18-2004, 03:54 PM
I love to drive
Ghetto Civic HX's Avatar
Default Re: cold air intake... (jaedaEG)
I have a 2000 civic and I didn't have to take the front bumper off. It's a little easier if you take off the front right wheel, but even that isn't needed. Just like someone else said, undo the front part of the fender lining and tuck it behind the wheel (or brake disk). from there you can pretty much take everything out.
Good luck
Ghetto Civic HX is offline
Old 08-18-2004, 04:26 PM
rac3rb0i's Avatar
Default Re: cold air intake... (rodrez)
96 ex
rac3rb0i is offline
Old 08-20-2004, 08:52 AM
rac3rb0i's Avatar
thanx guys for all the help.... i actually just installed the short ram and not the cai cuz that freakin U shaped pipe with the box at the end is a bitch to try to take out with out the proper tools and my dad took the tool box to work... it sounds great i love the sound of air being sucked in... lol... iono about the cai but for now the sri is good enough all i need now is a heat shield... again thanx guys for allt help
rac3rb0i is offline
Old 08-20-2004, 09:01 AM
Dacalac's Avatar
oh dear god the resonator box was suck a PITA! I hated that bitch box when I was doin a CAI install on my old sedan...
Dacalac is offline
Old 08-20-2004, 09:09 AM
jerbear!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rac3rb0i &raquo;</TD></TR><TR><TD CLASS="quote">thanx guys for all the help.... i actually just installed the short ram and not the cai cuz that freakin U shaped pipe with the box at the end is a bitch to try to take out with out the proper tools and my dad took the tool box to work... it sounds great i love the sound of air being sucked in... lol... iono about the cai but for now the sri is good enough all i need now is a heat shield... again thanx guys for allt help</TD></TR></TABLE>
rip that sucker out. take off ur bumper and start pullin ;D
jerbear! is offline
Old 08-20-2004, 09:11 AM
Senor Miembro
ecahatch's Avatar
you shouldn't have a hard time with the CAI.....it will be a good experience for you
ecahatch is offline
Old 08-20-2004, 09:19 AM
specv5150's Avatar
Default Re: cold air intake... (Dirk Lance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dirk Lance &raquo;</TD></TR><TR><TD CLASS="quote">oh dear god the resonator box was suck a PITA! I hated that bitch box when I was doin a CAI install on my old sedan... </TD></TR></TABLE>
It DOES suck. Fortunately when I was installing my charge piping, the bumper was already off so it made it ALOT easier
specv5150 is offline
The G2 Racer
Appearance Build Threads
294
07-27-2014 03:55 PM
rac3r
12-31-2004 07:21 PM
skr33t_rac3r
10-14-2004 05:18 PM
rac3rb0i
08-19-2004 10:27 AM
rac3rb0i
08-13-2004 10:54 PM
Quick Reply: cold air intake...
  • Ask a Question
Question Title:
Description:
