cold air intake...
ok i don't know shiet about my car does anyone have a installation for dumbies on installing ur cold air intake... got a 96 civic ex.... just got my cold air intake and i don't want to spend the 30 bucks and have the shop do it ... so need help installing it... if it isn't too hard.... thanx....https://www.procarparts.com/products/HD96CV-1897CIX.JPG
Modified by rac3rb0i at 8:39 PM 8/18/2004 |
Re: cold air intake... (rac3rb0i)
shouldn't be too hard as long as you can turn a wrench.
I know with my car (1999) you have to take the front bumper off, but thats just taking out 4 screws and a bunch of clips. Seriously its not hard at all to install an intake |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rac3rb0i »</TD></TR><TR><TD CLASS="quote">just got my cold air intake and i don't want to spend the 30 bucks and have the shop do it ... so need help installing it... if it isn't too hard.... thanx</TD></TR></TABLE>
What car? What motor? Save the money, do it yourself. You'll learn a little also. |
CAI install is easy. just grab the tools and go at it. what intake?
All you need it a Phillips screwdriver, 10mm socket, ratchet, and an extension.
Re: cold air intake... (XiiiXiii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XiiiXiii »</TD></TR><TR><TD CLASS="quote">shouldn't be too hard as long as you can turn a wrench.
I know with my car (1999) you have to take the front bumper off, but thats just taking out 4 screws and a bunch of clips. Seriously its not hard at all to install an intake</TD></TR></TABLE> Don't all civics from 92 and up require the bumper to be removed during installation for a cai? |
Re: cold air intake... (chronodyne28)
wow.... yea.. easy.... yea... search... but if this doesn't get flamed then there are plenty of guys in here that will help you out..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chronodyne28 »</TD></TR><TR><TD CLASS="quote">
Don't all civics from 92 and up require the bumper to be removed during installation for a cai?</TD></TR></TABLE> Pretty much. You need to get rid of that fat resonator box. Racerboi, the install is pretty straight forward. Remove the bumper cover, and the pull back the fender liner. Remove the resonator box (the bolts are sort of behind it, takes a second to find them), and remove the air box in the bay, and of course the rubber intake arm. Carefully place the new intake pipe into the bay, and loosely attach it to the throttle body with the supplied silicone hose and hose clamps. Connect the new cone filer, and put, double check the connections so they're secure, and you're not rubbing on anything. You'll probably have a spacer or grommet that goes between the car and the piping to hold it steady, make sure to secure it properly. Reinstall the liner and bumper, and you're good. |
Re: cold air intake... (Cult of Staxx)
i've never had to remove the bumper, just take off the wheel and pull back the fender lining. just unbolt the u-shaped tube from the box. take apart as much as u can connected to the resonator box, that will make it easier. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: cold air intake... (jaedaEG)
I have a 2000 civic and I didn't have to take the front bumper off. It's a little easier if you take off the front right wheel, but even that isn't needed. Just like someone else said, undo the front part of the fender lining and tuck it behind the wheel (or brake disk). from there you can pretty much take everything out.
Good luck https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: cold air intake... (rodrez)
96 ex
thanx guys for all the help.... i actually just installed the short ram and not the cai cuz that freakin U shaped pipe with the box at the end is a bitch to try to take out with out the proper tools and my dad took the tool box to work... it sounds great i love the sound of air being sucked in... lol... iono about the cai but for now the sri is good enough all i need now is a heat shield... again thanx guys for allt help
oh dear god the resonator box was suck a PITA! I hated that bitch box when I was doin a CAI install on my old sedan...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rac3rb0i »</TD></TR><TR><TD CLASS="quote">thanx guys for all the help.... i actually just installed the short ram and not the cai cuz that freakin U shaped pipe with the box at the end is a bitch to try to take out with out the proper tools and my dad took the tool box to work... it sounds great i love the sound of air being sucked in... lol... iono about the cai but for now the sri is good enough all i need now is a heat shield... again thanx guys for allt help</TD></TR></TABLE>
rip that sucker out. take off ur bumper and start pullin ;D |
you shouldn't have a hard time with the CAI.....it will be a good experience for you https://honda-tech.com/forums/images/smilies/emthup.gif
Re: cold air intake... (Dirk Lance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dirk Lance »</TD></TR><TR><TD CLASS="quote">oh dear god the resonator box was suck a PITA! I hated that bitch box when I was doin a CAI install on my old sedan... </TD></TR></TABLE>
It DOES suck. Fortunately when I was installing my charge piping, the bumper was already off so it made it ALOT easier |
