Code 9, H22 swap.
Hi, I have a 98 civic, with an H22a4 swap did myself. Has wireworx swap harness and P28 ecu with hondata S300 v3 done by hamotorsports. Got car running and throwing code 9, so I ordered new distributor and still getting code. Set timing at 16 degrees and double checked that timing belt has not slipped. Car runs horrible and driving it done the road it bucks bad. But when go full throttle the car pulls fine but part throttle or idle it runs rough and rich.
Re: Code 9, H22 swap.
Code 9 can also be caused by a bad CYP sensor wire or bad ECU.
Ohm test the CYP sensor from the two pins of the ECU connector. Post reading. |
Tested sensor with meter 480 ohms.
Originally Posted by matthewbuck2
(Post 51929092)
What @muellersfan said. Unplug the ECU (disconnect the battery first) and measure the resistance of the three distributor sensor circuits from the ECU plug. This test goes through the ECU adapter, the harness wiring, the plugs under the hood, and as a bonus, the distributor itself, all in one shot. Also test those sensor wires for resistance to ground, it should be open circuit.
Originally Posted by mk378
(Post 51929156)
(Post 51929352)
Yes I did the test as specified all came back good no shorts in the wiring either. But I also did a compression test and it’s not looking good. #1- 180 #2- 70 #3 190 #4 180. This would cause a miss from what I’ve found in research. But would it cause this code?
Originally Posted by JRCivic1
(Post 51929498)
Miss... YES. Code... Nope.
(Post 51929813)
So is the code even worth worrying about at this point?
VERY Low compression in cyl 3 --> definitely fix this problem there FIRST. Then go from there.
