code 43/3/8/22
i have a d16z6 with jumper harness running p28 ecu
im throwing 43/3/8/22 i understand 43 is fuel supply system could it be due to a fuel filter? 3 is a map im gonna try another map tonite whawt are 8 and 22? |
Re: code 43/3/8/22 (Ba4)
thanx i already found a thread with all the codes lol what can cuase the 22? my vtec hits all the time
and tdc? the map im gonna replace tonite, and fuel supply im going to replace the filter first i need to repalce it anyways |
Re: (Ba4)
while going on full thorttle and coming to a stop i ptu the car in neutral...the car shuts off i have to kick the clutch in could this be my fuel pump? i always here it prime
Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 »</TD></TR><TR><TD CLASS="quote">thanx i already found a thread with all the codes lol what can cuase the 22? my vtec hits all the time
</TD></TR></TABLE> Are you sure? I don't Think VTEC is suppose to work if you are throwing CELs. Your VTEC oil pressure in/on your VTEC solenoid. Check the wireing from the oil pressure plug to your ECU (Pin D6). |
F Code 43! It could be fuel filter, fuel pump, or simply the O2 sensor being a lil cranky... i resetted my ecu and it disappeared
