Code 41 H025 Heater?
Anyone ever had this problem? If so how do you go about fixing this problem?
Re: Code 41 H025 Heater? (B16Vtec)
Did you do a swap? More info needed to be able to help you....I did have such a problem.
code 41 is your heated oxygen sensor
i had the code when i installed my jdm header.i took the sensor out from the header and harness where it plugs in.i cleaned it with simple green on a rag and never got the code again.
