code 21
Old 07-08-2019, 02:11 PM
  #26
Jimster480's Avatar
Default Re: code 21
Originally Posted by muellersfan View Post
Assuming the ZC DOHC block is mated to a ZC DOHC head.
Well really the only other head that could be on it would be a D16A1 which is essentially the same/similar head as the JDM ZC DOHC (gen3).
Since its not a brown top with a vacuum advance distributor.
So either way that would work.
3rd Gen ZC Identified by: Internal coil, large distributor, single butterfly TB. Black cam cover. Cam cover bolts on the sides. Small cam pulleys. Inlet Manifold stamped PM7. +7cc PM7 pistons, 43 cc Pent roof combustion chamber. As a "ZC" this appeared in the JDM EF3 Civic and EF7 CR-X, and also in the JDM Honda Quint Integra GSi (DA1 chassis). This is the most commonly produced ZC, manufactured in Japan from end of '87 through to early '91 D-series version D16A8/9 (Euro Civic Si) (sometimes +7cc P29 pistons)
^ Looks like the one he has as the cam cover bolts are on the sides and it has a JDM cam cover plate (you can see the japanese letters on the cover).
He could also use P29 ECU according to this information.
But all of the engines I mentioned make similar power with similar specs and use similar/same casting heads.
Jimster480 is offline
Old 07-08-2019, 02:14 PM
  #27
muellersfan's Avatar
Default Re: code 21
Sounds good.
muellersfan is offline
Old 07-08-2019, 10:06 PM
  #28
Default Re: code 21
great now that we ALL agree what i have which i must thx you first and move on to the real problem plz help me find the water outlet i listed the part number in a previous post as 19315-pg6-010 is under a late 80's acura integra its the only one i saw that was on the left side of the distributor and without an extra outlet but has been discontinued?????
xamdam67 is offline
Old 07-09-2019, 03:47 AM
  #29
tony_2018's Avatar
Default Re: code 21
if it's a discontinued part you'll have to go junkyard hopping.
tony_2018 is offline
Old 07-09-2019, 08:30 PM
  #30
Default Re: code 21
OP, why are you killing yourself trying to find an upper water neck with a bleeder valve ??? PLENTY of Honda engines do not have them and can be successfully bled without a bleeder valve/screw... a bleeder bucket can be purchased at most local auto parts stores and this device is extremely effective in eliminating air pockets and bubbles within the cooling system and can solve this issue for you.
I haven't opened a bleeder screw in years... the bucket does the job.
JRCivic1 is offline
Old 07-10-2019, 08:06 AM
  #31
Default Re: code 21
if you had read the earlier post is says i broke it when you break an aluminum part you tend to fix it THATS WHY
xamdam67 is offline
Old 07-10-2019, 09:14 AM
  #32
Default Re: code 21
Not sure you read and understood JR's helpful advice. Instead, you instantly reacted emotionally in defense mode, as usual.
Old 07-10-2019, 04:27 PM
  #33
tamboo's Avatar
Default Re: code 21
yeah get one of these, i was going nuts and it finally saved my bacon:
Amazon Amazon
tamboo is offline
Old 07-11-2019, 09:17 AM
  #34
Default Re: code 21
housing is cracked cant use it, dont need a bleeder bucket either, i do know how to bleed a coolant system TROLLS NOT WELCOME
xamdam67 is offline
Old 07-11-2019, 01:18 PM
  #35
Default Re: code 21
TROLLS NOT WELCOME
This^ unexpected introspection is a positive sign because the truth will set you free.
Old 07-11-2019, 06:32 PM
  #36
Intelligently Stupid
TomCat39's Avatar
Default Re: code 21
It appears you don't want assistance and feel positive advise given is an attempt to troll.
I believe it's time you move along and find assistance elsewhere if you are going to maintain an attitude as seen here.
TomCat39 is offline
  • Ask a Question
Question Title:
Description:
