Code 14 Help me PLEASE!!!
alright fella's \
one long light and 4 short ones = code 14
according to this link
http://www.c-speedracing.com/faq/05.php
CODE 14
88-98 Civic
97-98 CRV
88-98 Prelude
94+ Integra IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
ok people... help wayne... well... help myself **** in this case what do I do, the engine fell over and broke my stock map sensor. So my brothers friend had a spare one, however I believe the clip for the harness broke on it so it comes loose so says my little brother I didnt pay much attention to it... I am going to have Charlston set the idle and everything at peirce when I hook it up to thier diagnostic machine...
but until then any possible fixes to this problem...
the car has a funky spiking idle between 1500 and 2000 when you let the car sit and idle after being run and when you run the car in that rpm in gear it feels like you are teaching someone to drive stck but above or below that rpm range it runs fine...
if I turn the car off and turn it back on the idle spiking stops...
any idea's fellas
CODE 14
88-98 Civic
97-98 CRV
88-98 Prelude
any idea's fellas
Re: Code 14 Help me PLEASE!!! (137)
you tried cleaning that screen on the IAC valve yet? could be clogged. a little carb cleaner/fuel injected cleaner works wonders.
to check if the IAC is defective; jump wire A9 and A23 you should hear a clicking sound from the IAC, if you do it's good it not it's bad.
