CN2 usb hook up help.
i have look on PGMFI and could not find the right color match. they have a link to another web but i cannot view, im Forbidden to view pics. so if you would not mind telling me which color i start with 1,2,3,4 thanks.
Re: CN2 usb hook up help. (SlowerEJ8vtak)
Re: CN2 usb hook up help. (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">what are you try to do? data logging?</TD></TR></TABLE>
Yes, I had that same cable, and I found the colors in the forum, search dku5 and you'll get it, I've lost the link now though.
I've quit using this account
i thought it depended on which cable you had?
here is how its connected on the ecu:
ground (pin 1 on the ecu)
Tx (pin 2 on the ecu)
Rx (pin 4 on ecu)
Rx (pin 4 on ecu)
http://forum.pgmfi.org/viewtop...=dku5 is one thread, but the guy didn't get it working, back to the hunt.
EDIT: found it: http://forum.pgmfi.org/viewtop...=dku5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">White and the ground shield go together to PIN 1 (GND)
Red goes to RX PIN 2 (RX)
blue goes to TX PIN 4 (TX)
yellow and green are not used. </TD></TR></TABLE>
Re: (SVOboy)
wow. thanks. one question.
White and the ground shield go together to PIN 1 (GND)?
GROUND SHIELD? is that a wire? i just have blue white red after removing green and yellow.. red looks orange to me. the picture makes it look red.
