clutch squeaks on 97 Civic
Old Member
It still squeaks like an old car everytime I shift. In fact, it sounds worst now than before. What should I do? Do I need to grease somewhere? If so, please be detail because I can find where it may be.
Thanks
Thanks
Re: clutch squeaks on 97 Civic (acydphryck)
I have the same problem on my 98 , especially when it is cold out. My squeeky is coming from under the car. Im sure WD40 would work but its only a temp. fix. Is there any industrial grease or somthing that can be used?
wd40 should work...just gotta find the squeak spot...no pun intended...
Old Member
Re: clutch squeaks on 97 Civic (binkster)
Here is the reason why it squeaks. I washed the engine, so I must have rinsed off the "grease" somewhere. Where I don't know. Can someone recommend where to buy "grease"?
