clutch problem??help
car is a 94 ex with a D16z6 swap
what is happening is when i start the car from sitting for a couple hours i have to pump the clutch alot to put it in gear. also after driving for a while in 5th you have to pump it to get it back (literally clutch will go all the way to the floor) and keep pumping to get into 1st.
is it the clutch master cylinder?the clutch is brand new
anyone have experiance with the Omni Power Quicklutch Master Cylinder?theyre universal to all civics 92-95 right?
Re: clutch problem??help (pepperinyoureye)
Try bleeding the clutch system.
Also, take a look under the dash where the clutch pedal connects to the master cylinder, they will typically leak fluid in that area when they are going bad.
If you have the first generation of the Omni quick clutch m/c they had defective seals that were not compatible with all brake fluids out there. They have since revised them and the seals have been tested with most any brake fluids. It came about from that they only tested the first revision with honda fluid and nothign like ATE etc.
deff leaking fluid where it connects to the master cylinder....means m/c is bad right? if so what are your opinions/experiances with the omni power quicklutch ?
B_Swapped93
09-19-2013 04:42 PM
afropuffs808
05-02-2008 06:17 AM
