obd2-obd1 GSR swap (now Cylinder Pos. sensor error code)
Old 06-07-2010, 10:46 PM
pitchblacksvt's Avatar
Default obd2-obd1 GSR swap (now Cylinder Pos. sensor error code)
I have a 99 civic dx i just swapped in a OBD1 gsr, i have converted it to Obd1 (ecu,injectors,dizzy,alt.). I depinned and repinned the dizzy wires and have checked them over and over even changed them and everytime i start the car i get a error code for cylinder position sensor. Thinking it was the dizzy i replaced it with another one and the same thing. Any ideas? I'm stummped!
Old 06-07-2010, 11:23 PM
raidacaipo's Avatar
Default Re: obd2-obd1 GSR swap (now Cylinder Pos. sensor error code)
this problem is common. Where did you get the diagram for the dizzy colors? that diagram is wrong!! Let me know the source of your dizzy diagram and Ill see if the colors are correct.
I had the same problem from this diagram: http://www.phearable.net/tech/wiring...istributor.jpg
THIS IS WRONG! just find your CYP color and try and match them. I told phearable about this diagram and how its wrong and how they should correct it but they never have.
Old 06-08-2010, 01:25 AM
I used the same diagram as posted. Any info that can help is greatly appreciated.
Old 06-08-2010, 01:28 AM
I tried so many different ways with the wiring and moving this one and that one still to no avail.
Old 06-08-2010, 03:09 AM
raidacaipo's Avatar
Mines was a little different because I had a 96-98 engine harness. I think it was the CKP wires that got switched around with the RPM lead signal. However, the 99-00 engine harness dont have the RPM lead signal pin. I'm not sure so Ill double check the wire colors tomorrow when I can and post it up here.
Old 06-08-2010, 01:05 PM
Thanks greatly appreciated im ready to be done with this ordeal.
Old 02-24-2012, 01:09 PM
nitrouspete's Avatar
im bringing one back from the dead.. i am having the same code, 96 ex coupe with a gsr swap. i bought the car and cant get it inspected because of the check engine light for the cyl pos sensor. does anyone have a pic or diagram or know which wires go where?
Old 03-05-2012, 06:11 AM
I ended up just matching the wire colors from harness to dizzy and it was fine after that. Motor is out now goin onto a built ls/vtec setup!
88efsedanlx
12-10-2011 05:40 PM
DA9Sleeper
11-06-2011 06:57 AM
Eresuncabron
12-19-2003 09:17 PM
ZCrex90
05-29-2003 07:43 PM
evil_elmo
04-16-2002 05:48 PM
Quick Reply: obd2-obd1 GSR swap (now Cylinder Pos. sensor error code)
