clutch petal
clutch petal
ok here is the deal i finally got my swap in and running(b16) in my 97 civic lx i have minor problems like my valves need to be adjusted and i need to check the timing belt tentionor but now i have a new problem i bleed the clutch line because i had to get a new slave cylinder because mine was leaking and now with the engine off the clutch petal goes in and out like normal but when the engine is on the petal doesn't come out all the way and i have no clue why! i have a Centerforce Dual Friction Clutch kit in the engine. anyone one have any clue why it would be doing that? please let me know thanks guys
Re: clutch petal (mrnice1058)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrnice1058 »</TD></TR><TR><TD CLASS="quote">wow really how is that going to work thinking about that i will get burned by the exhaust. anyother ideas?</TD></TR></TABLE>
bleed it when its running *****
Re: clutch petal (yaya)
lol ok i didn't think that would make a difference can you tell me how it is different? i am taking your word for it but i just want to know how it is different
I dident think the clutch pedal was assisted in anyway by the engine like the brake pedal for example. But thats just my opinion and i could be wrong.
Re: clutch petal (nocternaldragon)
honestly i really dont know either. i was thinking the clutch might run off the brake booster as some vehicles do. i bled mine with the engine off, and it took a long time btw.
When i bled mine, i ussed the sucktion a ma thingie and did it that way cause that resivior was soooooooooooooooooooooooooo teeny i dident want to pump it up let it out and blah blah blah......
grab a friend. you have to pump pump pump pump...... and hold, bleed.....
i had to do this like 20 times for some reason when i put my b18 in my civic
did you have the same problem? i mean when i step on it with the engine off it is perfect but when the engine is running it engages quickly but the petal doesn't come out all the way it gets stuck half way but is doesn't rub or anything while it is halfway in i don't get it...
Vp Special K
08-25-2004 10:08 AM
