Removing side Moldings
hi
i have a 99 civic silver, however the lower skirt n side moldings are black, i know how to remove the skirt its just some screws, however the side moldings are abit tricky!! do they just snap off, do i have to remove the inner panels of the front n rear doors? i want to paint them silver!
thanks
thanks
Re: Removing side Moldings
hi
thanks
thanks
remove cover by the mirror there is a screw in behind the innir door handle one in the door pull arm rest and 3 in behind the speaker cover then the rest should just be clips i think best to start at the bottom and work up the top hooks over the edge of the door good luck post some before and after ppics when you get it done.
verseone
09-11-2003 07:41 AM
