clutch free play
Re: clutch free play
open the bleeder screw without holding down the pedal and see if there are any air bubbles coming out if so wait till there no more
ok to help us understand more of your problem please give some details on what you have done or are trying to figure out what has been replaced .
I would check for possible leaks in the system. If it was fine and then just started I would suspect a leak or a clutch master failing. Check to see if you have full travel at the slave cylinder.
Check to see if you have full travel at the slave cylinder. Could be internal failure in the clutch master. You could also adjust the pedal free play and monitor it.
the bolt behind the pedal are not loose,so i don't want to adjust it.i do see some fluid coming behind the pedal which is the master cylinder,but only little bit
The clutch is self adjusting. I would be looking at a new clutch master in addition to that you will also need to adjust the pedal play when the clutch master is replaced.
gsr camel
09-13-2001 12:05 PM
