Clutch fluid change?
Any walk throughs on how to change clutch fluid on here? The clutch fluid on my new car is black.
Re: Clutch fluid change?
Follow the bleeding procedure in the FAQ until the fluid comes out clear
patience ! you'll need it lol
I would go to HF and get a one man bleeder. Attach to slave cylinder and bleed. Took all of 10 minutes to do myself.
I use a marinade injector to suck the fluid out of the reservoir before bleeding, less old fluid to push through the system
I just got a hose and filled a water bottle 1/2 way full with fluid and submerged the hose and bled for a few mins.
Take tube, an old pop bottle, and a bottle of brake fluid. One end of tubing on the bleeder, one in the bottle. Loosen bleeder till fluid starts coming out. Just keep manually pumping the pedal (it will not return to upright position) and filling the master cylinder until clear fluid comes out the slave. Tighten and enjoy.
