Clutch engages at the top of the pedal travel
hey my clutch engages at the very top of the pedal travel.. I just changed the master cylinder.. that didnt fix the problem. watelse can be the problem?
thanks!
thanks!
Re: Clutch engages at the top of the pedal travel (TORQUE MONSTER)
I know its hydro, i read your post.
Clutches are self adjusting, so if indeed it is grabbing at the end on the pedal travel, one thing to suspect is what i mentionned earlier.
Did it just start doing this?
fs
fs
Risky Business
Re: Clutch engages at the top of the pedal travel (filthy_shovel)
Grabbing at the top of the pedal is a sign of the clutch wearing out. Try re-bleeding your system. Also, try adjusting the pedal free play (locknut C).
Re: Clutch engages at the top of the pedal travel (95cxhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95cxhatch »</TD></TR><TR><TD CLASS="quote">great info and diagram Bauley!!!
we could all use this to understand how it works</TD></TR></TABLE>
Buy a manual... It's all in there
filty_shoval: Oh ur saying the self adjusting machism is faulty? I got ya.. thats a possiblity..
I bought the car with the problem
yea i bleed it pretty well and the clutch grabs pretty hard and theres no slipage at all..so i think the clutch itself is ok..
Adusting the C nut:
Adusting the C nut would just keep the clutch released? cause if its engaging at the top.. making it shorter would just make it depressed all the time.. am I understanding this right?
Adusting the C nut:
Risky Business
If you adjust the locknut you can have the clutch engage at a lower point on the pedal.
I really wouldn't worry about it though. Most OEM clutches i've driven engage near the top. Hell, my dads 01 civic was like that from the factory.
Re: Clutch engages at the top of the pedal travel (BauleyCivic)
I like having my engagement high on the pedal travel, so i dont have to push it all the way down... I dont know why, I just like it better...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">If you adjust the locknut you can have the clutch engage at a lower point on the pedal.
THat's exactly what i am saying. But usually, the adjustment is not something you fiddle around with alot. But it may be a possibility.
I would not re-bleed unless your pedal is acting funny...
fs
fs
skhell
Transmission & Drivetrain
06-23-2010 12:11 AM
FLCivic
06-30-2004 03:48 PM
