clutch disc can only go in one way?
Just wanted to know if the clutch disc can only go in one way right? Wasnt sure if i put it in the wrong way or not. But if i did the pressure plate wouldnt be able to bolt back up? How would i know if i did it right or not.
Re: clutch disc can only go in one way? (hmtcrxsir)
One side of the hub sticks out more. I want to say thats the side that is twoards the flywheel. Check your Helms, but no, you need to put it in like you took it out.
Re: clutch disc can only go in one way? (Ricey McRicerton)
You mean the side that sticks out more should face towards the flywheel side?
You're right, it should only fit one way.
