clutch, axles ?
clutch, axles ?
when i drive my car in the 1st gear and then floor the clutch when the rpm reaches 6-7 i hear i knock sound from the front, it feels like the front of the car falls down and then when i shift 2 the 2nd it goes back up again.
and when the rpm is around 3-4 and i shift to the 2nd nothing happens.
does it have anything to do with the axles?
I have another question and its about my 3rd gear, if the rpm is 4 and above and i shift to the 3rd a sound comes out of the gear, it sounds like i'm trying to shift without holding the clutch.
this issue happens in the 3rd gear when i'm shifting from 2nd 2 3rd and the rpm is above 4.
my friends told me its the clutch slipping and i need a new clutch kit before it slips in all the gears.
what do you guys think ?
bump the topic with ur opinion on my 2 questions and i'll be thankfull
Re: clutch, axles ? (gray_civic_coupe)
I'd have to hear the noise to be sure, but the first noise sounds like a possible bad motor mount. The other could be a bad synchro, or something else in the transmission. Hard to say without actually hearing the noise...
Re: clutch, axles ? (anony95ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anony95ex »</TD></TR><TR><TD CLASS="quote">I'd have to hear the noise to be sure, but the first noise sounds like a possible bad motor mount. The other could be a bad synchro, or something else in the transmission. Hard to say without actually hearing the noise...</TD></TR></TABLE>
thnx for ur opinion
thnx for ur opinion
I'll second that
I'll second that
Re: clutch, axles ? (EJ8VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC »</TD></TR><TR><TD CLASS="quote">if it was the clutch it would do it in all gears</TD></TR></TABLE>
it used to happen for my friend in his 2nd gear and then one after all and now after he changed his clutch kit everything works fine !
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gray_civic_coupe »</TD></TR><TR><TD CLASS="quote">
it used to happen for my friend in his 2nd gear and then one after all and now after he changed his clutch kit everything works fine !</TD></TR></TABLE>
then it was prob the throwout berring, not the clutch itself
thatonedsm
Transmission & Drivetrain
16
01-29-2024 10:38 PM
MatticusContra
01-10-2008 11:27 AM
