Cluster No worky, Or Turn Signals
Well my friend Jump started his car, and then all of a sudden his Cluster stopped working as well as his turn signals. We checked every single fuse in the car. The hazards work, but No L/R. Also all the lights come on as far as oil pressure, cel, and otheres (Except signals). What could it be? its a 92 cx hatch witha z6 in it.
*Update*
Ok now he says that he went to jump the car, and somehow he had the cables backwards(i know i know he is weird.) well the radio stopped working, and so i told him to check the engine bay backup fuse it was blown so he replaced that and the radio started to work again. When he was changeing the fuses and checking them then as stated above the Cluster and Turn Signals stopped working.
Modified by sohcvtec1995 at 9:45 PM 7/7/2005
*Update*
Re: Cluster No worky, Or Turn Signals (sohcvtec1995)
Do the tail lights light up? I had that problem in my gsr when i had it the instrument cluster wouldn't light up the turn signals didnt' work the hazards did and the tail lights didn't i checked the instrument cluster fuse 10A i believe and didn't look blow but i replaced it and it worked fine after that.
cables backwards?
your supposed to have the positives connected to each other and the negative terminal of the good battery grounded to the chassis of the car with the dead battery.
so are you saying he connected negative to positive and attempted to ground the positive?
Re: (ConceptS14)
are you attempting to help? did you even read the whole post?
I said he jumped the car the cables were backwards, and now the cluster dosent work, nor do the turn signals. thats what we are trying to figure out, not how to properly jump a car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">Everything works except Rpm, Speedo, etc etc, and the turn signals.</TD></TR></TABLE>
same thing happened in my EK.. it ended up being hta cluster.. i checked & replaced tha CLuster fuse -- it was tha cluster.. it howu some how .. grounded otu.. or decided it wanted to be retarded, like pinched its own line.. either way.. replaced it w/ another one i had.. everythign worked fine!
Re: (youknowwhoibee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youknowwhoibee »</TD></TR><TR><TD CLASS="quote">there is a 7.5 amp fuse that is in the engine bay. It happened to me also and all i did was change the fuse and i was alright</TD></TR></TABLE>
Checked that it was blown, we replaced and his radio started working.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CYM19z »</TD></TR><TR><TD CLASS="quote">
same thing happened in my EK.. it ended up being hta cluster.. i checked & replaced tha CLuster fuse -- it was tha cluster.. it howu some how .. grounded otu.. or decided it wanted to be retarded, like pinched its own line.. either way.. replaced it w/ another one i had.. everythign worked fine!</TD></TR></TABLE>
thats what i thought it was. I guess we will try that next
Re: (95DxSi-R2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 »</TD></TR><TR><TD CLASS="quote">he's lucky he didn't blow up his battery</TD></TR></TABLE>
that's what the fuse is for.
looxs
11
02-05-2007 04:06 PM
rodimus
08-03-2005 06:57 PM
mrbsponge
12-31-2003 03:31 PM
Dancing is Forbidden
09-03-2003 11:25 AM
