cluster help. eg
Old 09-28-2009, 01:25 PM
Your Name's Avatar
Default cluster help. eg
hello.
i have a 92 cx
the cluster works fine when the lights are turned off. rpm works . gas work.
but when i turn the nights on . the rmp and mph gose flat and dose not work.
the blinker lights stay come on. and stay on. but dont flash. just light up.
the gas and temp. gose to full and hot..
and the lights the light up the cluster dose not work..
what could this be?
plz help.
Old 09-28-2009, 01:43 PM
Your Name's Avatar
Default Re: cluster help. eg
bump
Old 09-28-2009, 01:51 PM
Former User's Avatar
I would start by checking your combination switch.
Old 09-28-2009, 02:46 PM
Your Name's Avatar
its not broken. could it be that?
Your Name's Avatar
works fine
Old 09-28-2009, 03:00 PM
Your Name's Avatar
checked that and works good.
Old 09-28-2009, 06:15 PM
shawn_crx's Avatar
If you have a CX with a RPM tach, you or someone had to redo the wires..... I would check the ground wires and recheck all your wires.
Old 09-28-2009, 08:23 PM
Oh look, I can change this
deschlong's Avatar
^^^ Well, they didn't redo the wires (a cluster with RPM/tach is plug and play into a CX), but I have seen a poor ground/bad wiring do wacky things to a cluster. First thing I'd check is whether all the wiring is correct -- as in, in its correct pin locations on the connectors behind the cluster. Get out your Helms and check them one by one.
Old 09-29-2009, 06:08 AM
shawn_crx's Avatar
was checking if he got an difference cluster in there instead one from EG cluster.
Old 09-29-2009, 11:01 AM
Your Name's Avatar
the cluster was changed. and we put a jdm cluster on and did the same thing.
Old 09-29-2009, 11:02 AM
Your Name's Avatar
took the car 2 ericks racing in CA, and they dont know what it is... something 2 do with the wires.. but it just started.. i had the car for about 3 weeks and it just started happing 3 days ago.
Kid_SiR
03-21-2008 10:42 PM
mugencivic94
08-17-2007 09:54 AM
CO_HaTcH
05-03-2006 08:13 AM
American.Graffiti
11-01-2005 08:18 PM
opiumdaze
04-10-2005 05:24 PM
Quick Reply: cluster help. eg
