cluster and climate control light problem
i have a 95 civic si and i just put in all new light bulbs in my guage cluster....now my cluster and climate control wont light up at all when i turn on my lights..i checked all the fuses and they are good..anyone have an idea on how i could fix this....TIA
Re: cluster and climate control light problem (usdmEFboy)
a short or grounding problem maybe?
Is the dimmer switch plugged in?
i dont really know anything about electrical or w/e so where would a ground wire be?? and is the dimmer switch the one that makes all the lights brighter...
What all did you do? Just took out the cluster to put new bulbs in? Make sure they're all in solid and all the connections are back in the back of it, as well as anything else in the region. clock, warning lights, dimmer, climate control, etc.
my eg hatch has the same problem. When i push in the dimmer switch it turns on. It has to be the wires behind or that are connected to the dimmer. trust me i have the same problem.
