Clunking noise
Old 08-09-2013, 09:18 AM
globy123's Avatar
Default Clunking noise
Hello. I have a 99 Honda civic LX. When I step on the brake pedal and make a turn there is a clunking noise coming from the front right passenger side. I turned the wheel and pulled back and forth on the tire..there is movement on the ball joint that connects the knuckle to the strut. Do I need to replace just the ball joint or the knuckle with the ball joint?
Old 08-09-2013, 09:29 AM
HOMEMADEPOWER's Avatar
Default Re: Clunking noise
It might be your tie rod but I would check to see. Inspect you upper/lower ball joints,tie rod and axle.
Old 08-09-2013, 01:20 PM
B_Swapped93's Avatar
....you don't need to replace the knuckle in either case. the upper ball joint will require that you replace the whole upper control arm tho. lower the knuckle WILL need to come out. i'd say inspect the axel but if you say the wheel moves i'd say tierod
Old 08-09-2013, 01:46 PM
b20bFourDoorCivicLX's Avatar
If you dont know what it is. Dont drive the car like that. Take it to a shop get it diagnosed asap. only creating more problems...D-E-F-I-N-I-T-E-L-Y dont drive on the freeway
derrack
Suspension & Brakes
01-23-2017 03:11 PM
MechEng
08-09-2011 02:13 PM
SIDreamer
02-24-2011 09:27 AM
tigueremalo
07-14-2006 04:28 AM
Quick Reply: Clunking noise
