clock and stereo reset, dim
After I shut off the civic, when i restart it, the clock is reset to 1 o clock and is very dim. I noticed the lights under the heater controls don't turn on now. The stereo is also reset, stations are cleared. I checked fuses under dash, look normal. Checked stereo wiring (because that is what i was changing) and it looks normal. I was taking an old stereo out (aftermarket) and putting the stock casette player back in, as I was taking the old stereo out it sparked because the wires connecting to the back of the stereo terminals were open and close together. Then it stopped working. Factory stereo does work now, but everything is reset after engine is stopped. Any ideas or solutions would be sweet. Thanks!
Re: clock and stereo reset, dim (Targa250R)
chec the fuses in the engine bay i blew a fuse in there changing to aftermarket hu before + did you pull the fusees out from under the dash? it should be a 7.5 fuse but check in the engine bay
upstate
07-27-2004 09:19 AM
