Clock spring resetting?
i need to replace the clock spring on my car and dont want to spend $240 at the dealer. i found a used one on e-bay for $45 but i have read that when a used one is being installed that the clock spring must be reset or it will just break again. is this the proper method for resetting the clock spring?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">When you are reinstalling the reel, install the column covers, replace cable reel, center it by rotating it clockwise till it stops. Then rotate it counterclockwise (approximately two turns) until:
-The yellow gear tooth lines up with the alignment mark on the cover.
-The arrow mark on the cable reel points straight up
Install steering wheel and attach 3-P connector to the clip, connect horn, and cruise control swtiches , install airbag, connect reel6-P connector to SRS ma9in harness, then install hte knee bolster and dashboard lower cover.</TD></TR></TABLE>
and is there a more detailed procedure for resetting the clock spring??? i have searched with no luck
honda genome
01-19-2008 01:44 AM
