Climate control Problem.
okay i have 96 civic LX.
The **** on my climate control doesn't go all the way to the right or the left. The **** that you use to change from hot to cold
it moves left and right but doesnt go all the way left or all the way right. So when i need to defog my windshield i try to move the **** all the way to the right and it always goes back towards the middle like a inch. same with the cold... so i can't get it warm enough to defog.
anyone have any suggestions?
Re: (qwrty)
or the valve in the engine bay is rusted stuck. check that out too.. just follow the coolant line from the head going back by the firewall.. theres a valve there that the cable connects too.
Re: (geebs)
haha so which one should i do first? check the cable behind the climate control? which means i have to take out the dash??
or pop my hood and check the coolant line and follow it to the firewall of the car..
I dont really know much about that part, where in the engine bay is the valve for the cable?
Re: (dth0ng69)
it is going to have to thick hoses connected to it with a metal looking cord kind of wrapped to it..just look behind the engine and you will see it..have someone mess with the temperature **** while you are looking and you will see it easier
Re: (DAP97SI)
Oh, So how do you take out the climate control with out taking out the dash??
Also i couldnlt find which hose was leading to from the coolant line to a valve.. i had someone move it back and forth i still couldnt find it.
thanks
thanks
