climate control isnt lighting up
so like the title states my climate control in my 99 civic hatch is not working..the 4 ways button lights up and the bottom 3 light up as well..its just the 3 on the side that contorl the tempature and where its blowing..any have a similar problem?? if so what did u do?
Re: climate control isnt lighting up
i changed the entire climate control with a new one..are there any fuses i should know about? inside the car or under the hood??
The Red/Blk wire and Red wire at the rear of the heater control panel supply voltage and ground to the light bulbs. Since some bulbs work, there's either a bad internal wire/socket or the bulbs are blown.
:D i will check if there is power to them..should of done that in the first place instead of being spoon fed thanks man, ill let u know how it goes
cutelilvi3tboig
11-04-2004 09:25 PM
ieatrice
05-03-2004 03:10 PM
