climate control??
climate control??
i was wondering , why does my a/c work one day and the next day it doesnt??
is it the actual climate control switch panel??if so how do i get the whole panel out of the dash?
will a JDM a/c switch panel work with no problems?????
its not the compressor, i mean you can hear it kick in when it works, and when it works it works good. if the compressor was bad it wouldnt work at all. its a 94 ex civic.
i found a couple of jdm a/c control panels on ebay for like 40$ btw.
Re: (graveltravel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graveltravel »</TD></TR><TR><TD CLASS="quote">its not the compressor, i mean you can hear it kick in when it works, and when it works it works good. if the compressor was bad it wouldnt work at all. its a 94 ex civic.
i found a couple of jdm a/c control panels on ebay for like 40$ btw.</TD></TR></TABLE>
This should have been in your first post in this topic....i assumed it would work one day then not the next (ie. low or out of freon) IF you think its electircal then yes you can purchase a JDM climate control....its plug and play.
hummss. does the a/c panel just pop out then, or is there another way to get it out????
are there clips holding it in???will i have to use a knife to pop pry it out?
