Climate Control ?
HT White Ops
Re: (JDM_EK4_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe »</TD></TR><TR><TD CLASS="quote">thanks
btw, its ek4 inspired i u know what i mean</TD></TR></TABLE>
Unless you've got a B16A2, Vi-RS front and rear bumpers, and a full Vi-RS interior, then I don't know what you mean...
(banned)
Re: (JDM_EK4_Coupe)
just tried switching the fuse, still no luck
A while back it magically turned on while i was driving then shut off suddenly. Any idea what this problem could be?
HT White Ops
Re: (JDM_EK4_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe »</TD></TR><TR><TD CLASS="quote">just tried switching the fuse, still no luck
A while back it magically turned on while i was driving then shut off suddenly. Any idea what this problem could be?</TD></TR></TABLE>
Try ******* with the plug on your dimmer switch. If they magically blink back on, and then off, then you need a new dimmer switch. If you've got a good friend with a 6th gen, then borrow his/hers.
(banned)
Re: (Eran)
Ok, i think i found the problem. I have an EK4 cluster and the dimmer doesnt plug into it. Is there some way i could splice the wires into it?
HT White Ops
Re: (JDM_EK4_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe »</TD></TR><TR><TD CLASS="quote">Ok, i think i found the problem. I have an EK4 cluster and the dimmer doesnt plug into it. Is there some way i could splice the wires into it?</TD></TR></TABLE>
The dimmer doesn't plug into the cluster. It's a "switch" that plugs into the dash harness.
HT White Ops
Re: (JDM_EK4_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe »</TD></TR><TR><TD CLASS="quote">its that little switch w/ the light bulb that gies left and right correct?</TD></TR></TABLE>
Yes
Yes
HT White Ops
Re: (JDM_EK4_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe »</TD></TR><TR><TD CLASS="quote">and it does not plug into the gauge cluster correct?</TD></TR></TABLE>
No, it plugs into the dash harness. It controls brightness on the cluster and radio. It does not affect: dome light, hazard/defrost, and axillary inputs (stock cd/tape slaves).
Re: Climate Control ? (JDM_EK4_Coupe)
ummm i have a 97 and the fuse said hazer mayb u should try checkin to c if it blew out and replace it cuhz mine went out but then i cahnge it and not it work lol
