clacking noise
clacking noise
Ok so last nite it started making a noise its kinda hard to xplain it looks like the noise is coming from the lower part of the motor its like clack clack clack it has the same noise at all times i really dont think is coming from the valves but i will do a valve adjusment soon could it be knocking ? is the piston hiting something ??
how would i be able to diagnose ? it a jdmB18c
I changed the spark plugs, the injectors lookd clean, it idels good the only thing left is the fuel filter but i dont thing it would make a diff.
Clacking from the lower part of your motor, eh?
Knock*knock, whos there?
your rods.
Id get that checked out right away at a mechanic, they would be able to diagnose it better than HT can based on your explanation.
your rods.
Holly **** so i took out the oil pan last nite every thing looked fine other than a hella fine almost gold dust ! i didnt find pices of metal ...i took the oil pickup line and the cover so i can see the crank i moved the fly wheel every lookd good the only off thing was that cilinder 1 made a noise like it was losing preusre the rest of the cylinders didnt make any noise also, were the rods conect to the crank i could move it just a lil in all four rods Are they supt to have any play ? ... what else should i look for ?? what should be my next step ?
Azxster
09-28-2007 08:16 PM
