Civic won't start after clutch master cylinder replacement
Hello all, So about 2 weeks ago i changed a faulty clutch master cylinder. I installed a new one and my car ran fine for about 10 min. of driving. I ended up parking it and had it sit at idle for 1 min and the car just shut off. almost as if someone just randomly turned off the car. i try turning it on and everything sounds healthy but it just doesn't turn on. and i smell some gas when i go check my engine after trying to turn it on. can someone help? thanks
Re: Civic won't start after clutch master cylinder replacement
Thanks. That's exactly what I did and it turned out that it was the coil. I fot a spark tester that plugs to the apark plug wire and saw there was no spark. And using my volt tester I saw that there was no spark at the coil. Then tested to see if there was a current running to the coil and THERE WAS. So in conclusion the coil was faulty and now it runs after the replacement. Now on how to mark this post as solved is another question.
Shocka1998LX
01-27-2020 09:11 AM
shocker911
04-28-2010 03:36 PM
J-Star
11-24-2005 07:33 PM
GetupHeights
09-23-2005 04:44 PM
