civic wont start
civic wont start
I have a gsr swap in my civic and tried to load a gsr map (hondata). started but idle was rough possible a vacuum leak. check for leak didn't find one. gave up so I reloaded the map that was prior and now car wont start. any ideas what went wrong?
The Grumpiest
Re: civic wont start
You're in the wrong forum. This is an engine management/Hondata issue. Try the Hondata forums of the engine management section.
I also don't see how loading the previous MAP caused the car not to start if it worked before. What happens when you load the new MAP back on it?
when I loaded new map all I did was disable knock sensor and heater. changed the injector size because I have a 660 and put in 240. calibrated tps. started but rough idle like the idle air control was bad/dirty. tried messing with it a little gave up. then loaded old map now wont start.
aznfreakyguy
07-03-2011 12:24 AM
