Civic vs. Integra shifters
Is the shifter from an Integra the same as a Civics? Meaning, are the shifters interchangeable? My friend has a Skunk2 out of his 99 GS-R that he wants to sell me for use in my 98 Civic. Some manufacturers list the same part #'s, while some list different. Any thoughts?
Re: Civic vs. Integra shifters (Chris y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">you can put it in your civic if you have a GSR motor
otherwise no.</TD></TR></TABLE>
i thought it was only if u had gsr shift boot and seats??
Re: Civic vs. Integra shifters (DxHatchback)
so the integ shifter will with with no modifications? i thought you had to widen where you bolt the end of the shifter to the linkage...am i wrong?
Re: Civic vs. Integra shifters (Heinz57)
integra shifter has 2 bends...
civic shifter had 1 bend...
from what i hear, understand they both work...but it might put your shifter at a different position...
i drove my civic with the integra linkage with my stock shifter and it tilted towards the front of my car...with the integra shifter and linkage it sits perfectly....
It will work, but might not be positioned right...
Re: Civic vs. Integra shifters (degooser)
the skunk2 might fit in your civic...
but a stock integra shifter definitely won't. its too wide to fit in the shift linkage. i found that out after i bought someones teg shift rod
Re: Civic vs. Integra shifters (EJ8specR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8specR »</TD></TR><TR><TD CLASS="quote">the skunk2 might fit in your civic...
but a stock integra shifter definitely won't. its too wide to fit in the shift linkage. i found that out after i bought someones teg shift rod</TD></TR></TABLE>
the lower part of the stock integra shifter is wider than the lower part of stock civic shifters.... skunk2, however...may be different...
chizzadd
11-07-2005 05:09 PM
lightning
01-31-2005 05:46 AM
