Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Civic / Del Sol (1992 - 2000) (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/)
-   -   Civic sidemarker (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-sidemarker-3065969/)
kaison 06-19-2012 11:53 PM
Civic sidemarker
Hello there everyone, I have amber side markers on my 2000 civic si and I currently have option 3 wired up, and i was wondering if there is any way to have the sidemarker and blinker blink at a synchronized time?
A buddy of mine says there is a three wiring harness for sidemarker, however after calling shops and looking around, I was told that no such thing exists.
How do you want it to be wired? There are 3 options...
Option 1:
-Sidemarker is illuminated (providing your parking lamps are on)
-Otherwise, sidemarker is off (it will not blink)
Option 2::
-Sidemarker and blinker blink in phase (at the same time)
Option 3:
-Sidemarker and blinker blink out of phase (alternate illumination)
-Otherwise, sidemarker is illuminated (providing your parking lamps are on)
edit: http://losangeles.craigslist.org/sgv...072942702.html in this particular craigslist ad, there is an image showing the side marker with three wiring. Does anyone know where I can get those or what they are called? any information would be useful.
And yes I have contacted the seller, but he has only 2 wires coming from his side marker.
edit #2: here is a diagram of what im understanding. http://imageshack.us/f/191/sidemarkerdiagram.jpg/
Arts09 06-20-2012 12:36 AM
Re: Civic sidemarker
You have to wire your side markers to your corners we have a 3 wire set unless jdm or edm Idk your set up so yeah but I'm sure you know red is power black is ground green is blinker mount and wire should be that way the power wire on the side marker spilt to green and power and should be in sync
Arts09 06-20-2012 12:51 AM
The jdm look is side marker hot to corner green the signal and the sm ground to corner ground or frame the top is to have them on constant and blink
kaison 06-20-2012 03:40 PM
I just wired up exactly as this diagram is shown, and it failed :/
The corner and side marker does illunminate, but does not is unable to signal at all for both the side marker and corner light.
