Civic question...Which one?
I am looking for a 92-95 Civic hutch. I do know that they come with 8 or 16v but I would like to know if one is better than the other as far as transmission and other components is concerned (have to know for potential swap)
I finally decided to get rid of the DSM. All I need now is some sucker to buy it!!
Any advice would be greatly appreciated!! I am sick and tired dealing with the DSM problems.....Boost is good but in the DSM it comes with a price!! When of course I actually drive it I forget about the sh%^ I just talked............
Thanks a lot,
Nikos
PS.To Typer895:I am putting the POS on the paper...Please do not try to change my mind.....
Thanks a lot,
Nikos
Guest
Posts: n/a
Re: Civic question...Which one? (2 B 4GO10)
VX HB is the lightest
HX is good for a swap because it already comes with the VTEC wiring.
Si HB is the heavest because of all the options it came with.
http://www.sportcompactcarweb.com has stuff on their project Civic HB
New User
If your planing on doing a swap, don't worry about what tranny comes with what. VX, HX, Si are all wired for vtec, they are the easiest as far as plug-n-play. I would get the VX because its the lightest one made....just my opinion.
HT White Ops
I am looking for a 92-95 Civic hutch [sic]...
If it was me, I'd get a the latest model in the range of years you specifed, the lightest model, and do a swap with the best motor, i.e. a '95 VX Hatch [2094 lb] with a H22A.
Re: Civic question...Which one? (BlackDeuceCoupe)
Wouldn't an H22A be too nose heavy on such a light car? Especially for a daily driver. I think you'd be better off with a B16 or B18.
Well, it somewhat depends on what he decides to do with it. So, what are your plans? Drag, Auto-X, Daily driver?
Re: Civic question...Which one? (wizurdofawwz)
get the vx like everybody else is talkin about......perfect for a swap. they all are but its the beter one to go with as far a weight goes.
First of all I would like to thank all of you guys for your input.......
I want to use the car as a daily driver...Actually because I carpool to work I would only need to drive it one week out of every month so I figure that 3 weeks would be enough time to work on the swap. I also have a Volvo I can drive in case something goes wrong... If the swap goes as planned I would like to add some boost.... (suggestions are welcome).
I have been looking for one for he last month now and it is really hard to find a decent color. All I seem to find is green or some other weird color...
On H-T I have read that if you know what you are doing you can have a really nice setup for 6-8K...Is this true???
From what I read I think a VX should do it. I don't care if I need to roll down my window anyway....
I hope to find one soon. The DSM has pissed me off! Last 2 months I have bought a new 16G, (old turbo is going back to the car wjen I sell it),timing belt KIT, alternator, fuel filter,power steering pump, clutch,tires, etc.......
Most people tell me to keep it since I changed all that but I have a feeling that the tranny is next...It shows no signs but till I sell it I am taking it easy. This morning I got off the ramp and floored for 4-5 seconds. After I hit 125 mph on 4th gear I drove the rest of the way 60 mph! (No need to show up early in job.....state job.....)
Anyway I just want you guys to know I do appreciate your advice. My friend TypeR895 introduced me to H-T and since then I am hooked!!
HT White Ops
The 92 CX is also pre-wired for vtec. There is very little difference in the weight of the VX vs CX... and the CX is easier to find.
Adding the wire for VTEC is no problem anyway, I wouldn't that make your decision. Your main decision is whether you want to pay more for the Si or not. If not, then my advice is look for the cheapest thing you can find with a decent body on it.
Future Texas Boy
Plus, you can push a H22A to 650+ HP with bolt-ons. Here's what it'll look like...
Here`s a good example: Buddy does 12.50`s in a DX w/ h22, i/h/e, and an 80 shot.
Ryan
[Modified by vtecvoodoo, 4:36 PM 2/6/2002]
Former Moderator
Re: Civic question...Which one? (Ricey McRicerton)
All 1992 Civics are pre wired for VTEC.
The CX is just as light as the VX. the only difference is the light-*** VX wheels that you will get rid of anyways because they are only 13's.
Get a CX or VX. I sold my ols 1992 Si because it was too heavy - I got a 1992 CX instead.
HT White Ops
Re: Civic question...Which one? (vtecvoodoo)
Bolt-ons my ***. Plus, you don`t really need 650...
<u>APEXi DRAG INTEGRA</u>
SOURCE: Turbo Magazine Web Site
...The engine and drivetrain are a strange tag team of extreme and simple. The engine, which has high-tech components, uses simple street electronics to control fuel and timing, not a mega- expensive, race-only engine management system...
...One of the things we like about this high-tech marvel is that APEXi was smart enough to use its line-up of street electronics rather than a race-only system to control the H22A. The stock ECU has been replaced with an APEXi Power FC (December 2000, Turbo) "oversees the ignition timing and fuel delivery to the engine. The fuel system consists of two Bosch fuel pumps, -8 AN lines, 1,000cc injectors and an APEXi regulator mounted to a custom rail. The ignition side of the equation is made up of a system that retains the stock distributor cap as a crank sensor for the Power FC, but fires from a custom, direct fire set-up for maximum efficiency. The Honda H22A-based powerplant pumped out a fierce 609 hp on APEX Integration's Dynapack chassis dyno...
Want further proof? I'll be glad to embarrass you more...
HT White Ops
Re: Civic question...Which one? (YodaIsGod)
true...and H22 swap you lose P/S & A/C...
New User
The APEXi Drag 'Teg is the second fastest front wheel driving drag machine in the world. The reason it's the second fastest is because they use mostly APEXi bolt-ons; stuff that you and I can buy over the counter.
Re: Civic question...Which one? (93delsol)
650 with boltons?? Wow....i hope ur kidding....cuz that's the stunna mentality. I was in the same situation....but I decided to go with a simple gsr swap. I don't have much experience with hybrids...so jumping into an h22 swap seemed like a lil too much for now.
[Modified by Hanson, 4:17 AM 2/7/2002]
I thought they had custom valvetrain and crankshat in the integra to get that sucker to spin backwards in addition to a 6 speed tranny intended for a nissan? I mean i guess the turbo and liquid air I/c is all bolt on technically, but when is a bolt on no longer a bolt on. Technically I guess you can consider all the engine internals bolt on, and a turbo system can be bolt on if you buy an oil pan with the extra fitting. But for most people bolt ons stop at I/H/E, maybe fuel, nitrous or even turbo kit.
Anyways this is off topic now
Get a 5th gen si for a daily driver. comfort is nice, forget all this weight crap. If you need to go faster add more traction and hp
