civic problem
civic problem
i have a 1995 civic with 173000 miles. engine idles smooth.at 1500 -1800 rpms ,the engine starts to miss. at 2000 rpm,it smooths out and runs well. even on deceleration,when the tach hits 15-1800,it bgins to miss.good car,very irratating!any help is greatly appreciated.btw-its an automatic
Re: civic problem
I have a 98 civic lh and it will get a bad miss between 1500 and 2000 rpms. Is that also a coil problem. Also, this seems to happen along with that problem......when I stop for a short time and try to start the car again , it will not start for about 10 minutes. It cranks but does not fire.
Re: civic problem
tmont2... when your car finally dose start dose it run really rough for a few secs.? that would be a head gasket leaking coolant into the cylinders when cooling down and wont start untill it leaks past your rings into your oil.
Re: civic problem
It does not have any coolant in the oil. What about the miss between 1500 and 2000 rpms. What might cause that. The issue with not starting for about 10 minutes might not happen for a month, no consistancy. Same with the miss problem.
Re: civic problem
gabriel0830
12-15-2012 10:05 AM
