Civic not starting when hot
My civic was working properly but after service in Honda center started to make more heat and after some time not starting when hot , battery is new and sent to test the test was OK.
when cold will start immediately |
Re: Civic not starting when hot
Check main relay for solder cracks. Resolder or replace with new unit. Google main relay if you dont know what it is.
Mine was a loose connection to starter.
PGMFI relay. Pick one (or a few) from the salvage yard
bad etc sensor can do this.
test it on the car to avoid coolant system bleeding nightmares. see: https://mechanics.stackexchange.com/...start-when-hot |
Dear AllThanks for reply It was the ETC sensor connection and now working well for last two weeks |
